ArcGIS for Power BI - popups not working on tile layer (hosted) from ArcGIS Portal
832
03-07-2023 01:10 AM
_nerdy
I have an ArcGIS for Power BI map visual with a tile layer (hosted) from ArcGIS Portal. In Power BI desktop, when I load the layer into the visual and test the popup it works fine. When I then publish the Power BI report to a Power BI workspace the popup it does not work. In the service I can remove then re-add the layer in the visual and it works, but when I leave the visual and return to it later, the popup no longer works.
This seems like a bug. Has anyone had this issue and found a workaround?
Tags (1)
DIwanicka
I have the same issue using a Portal layer using version 2023.1.166 of the plugin in Power BI Desktop.
JoeSremack
Has anyone else seen this issue or have a workaround?  Just started seeing this after using and updating the map for almost a year.
