I have an online version of PowerBI (MacOS) and I have two datasets. They are both addresses and individually on separate maps they display data.
What I'm trying to do is overlay one dataset over another dataset (with different colouring) so I can view both datasets at the same time. However when I go to layers, all I can add are Demographics or ArcGIS layers, there is no where for me to import my own layer.
I've tried looking around the web but it seems everyone has a slightly different version to me and their solutions to add layers isn't applicable for me.
Would appreciate some guidance on how I can overlay two different datasets on the same map.
Bumping this one
Hi @JonathanParro,
Thanks for your question! ArcGIS for Power BI only maps one Power BI data layer per visual. To add additional layers, you could try to publish one of your Power BI data to ArcGIS. After that, you could add the data layer from ArcGIS in ArcGIS for Power BI. Then you will have both of them on the map.
Please let me know if you have more questions.
Thank you!
