Please add the ability for routing in the map to use a custom routing service published and registered with ArcGIS Enterprise Portal. Currently, the tool is only routing using the esri street network. Our own custom network is updated weekly with new road data which makes it much more accurate for our end users.
@EddieFung1 If you are using Power BI Report Server, we force the visual to use all the services available from Enterprise: Geocoding, GeoEnrichment, and Routing. This 'may' suit your needs, but we will continue to monitor this idea for others that would like a 'switch' to use Enterprise services over Esri's Location Services.
I would also be interested in learning more about your use case. Please feel free to DM me your contact info so we can set up a time to meet.
