Would like the ability to have the map extent dynamically filter visuals on the page. Currently you can use the select tool, but that limits to 250 locations. You can utilize the filter pane or filter visuals and the map will adjust, but it doesn't seem to work the other way. This would be useful if your locations are not already grouped and you want to view associated data visually through a geographical reference.
