ArcGIS for Power BI Blog
Other Boards in This Place
Latest Activity
(16 Posts)
NaZhang_Esri
Hope everyone enjoyed the Esri User conference this year! We heard a lot of feedback from you and hope to make some great changes to the component. This blog lists the frequently asked questions during the 2023 Esri UC. If you missed out the UC this year, don’t worry about it. Here comes the answers!
Read more...
more
3 0 1,262
NaZhang_Esri
Hope everyone is enjoying the summertime and here comes our hot ArcGIS for Power BI new release. Did you attend the 2023 User Conference in San Diego? It was awesome!
giphy
Read more...
more
3 1 1,167
NaZhang_Esri
It’s spring! Hope everyone is enjoying some flower blossoms. During this beautiful time, here comes our first ArcGIS for Power BI release in 2023.
Read more...
more
4 0 1,122
AnthonyLatini
It's the most wonderful time of the year! Cozy slippers, warm sweaters, snow (in some parts of the world), and another update in ArcGIS for Power BI.
Read more...
more
4 0 609
AnthonyLatini
Ah summer is here! Which means going to the beach, attending parties, staying cool, and of course, squashing bugs and enhancing features in ArcGIS for Power BI. Oh and I think the Esri User Conference is coming up!
Esri User Conference Info: Esri User Conference: July 11–15, 2022
Read more...
more
4 0 1,145
AnthonyLatini
Another release already? Seems just like yesterday that we had a release in ArcGIS for Power BI. Take a look at the work we've done in our second release of 2022!
Read more...
more
2 7 6,015
AnthonyLatini
Whoever said that bugs were actually a feature?
Check out some of the fixes and updates we made in ArcGIS for Power BI to kick off the 2022 year!
Read more...
more
2 18 2,137
MrinmayeeBharadwaj
2021 was a BIG year for the ArcGIS for Microsoft 365 team here at Esri!
Read more...
more
0 0 352
SeanKMcGinnis
As organizations look to improve efficiencies by leveraging robotic process automations, many are adopting Microsoft’s Power Automate to support their automated workflows and data pipelines. We have started building the ArcGIS Connectors for Power Automate to help extend the Flows to leverage your geospatial content.
The biggest consideration to be aware of when starting to build Flows in Power Automate using the ArcGIS Connectors is record count. Record count is important for a few reasons:
  • HTTP request time limits in Flows
  • Maximum of 5000 iterations the ‘Do until’ control can handle
  • Getting consistent results
Power Automate has HTTP request limits and timeouts for connector operations that take longer than two minutes. Geospatial can have thousands of records and when working with complex geometry, the size of the data grows, and processing can take a while.  To prevent the connectors from timing out, the ArcGIS and ArcGIS PaaS  connectors have been built with 150 record count limits to help prevent timeouts from occurring.
As we know, many datasets we work with have more than 150 features, but the ‘Do until’ control allows us to iterate through the data in 150 record chunks.
There are a few steps to getting the ‘Do until’ control set up to step through your dataset:
  1. Initialize a variable to track the offset as the Flow iterates through the records
  2. Wrap the logic for each record in a ‘Do until’ control
  3. Update the offset variable with the current offset of the record you are working with
This pattern will allow the flow to iterate through the records with less concern of the control timing out.
For those new to programming concepts, below are a few resources to provide some additional understanding:
One thing to be aware of, the ‘Do until’ control does have a maximum number of iterations that it will run. By default, the control is set to run 60 times. The count is configurable and can be set to run a maximum of 5000 times. For other configuration options and design considerations, check Microsoft’s documentation.
Finally, record count is an important consideration for consistent of results. In our testing, we have seen discrepancies in the result counts when working with large datasets and have found working with data that is 5000 records or less has much more consistent results.
To summarize:
  • Record count and data size is a VERY important consideration when building your Flows in Power Automate.
  • Use the ‘Do until’ control to facilitate the iteration through the individual records.
  • Configure the ‘Do until’ count limit to support the number of records you expect to work with each time the Flow is run.
more
0 3 2,442
ScottBall
We've received a number of questions regarding how and when Power BI data is sent to Esri when Power BI users interact with the ArcGIS Maps for Power BI visual. I'd like to share these answers with the community so everyone is aware of when their data is - and isn't being sent to Esri for geoprocessing.
Q: There are data going to and from the ArcGIS site.  I am assuming this is just address data for mapping purposes only. The question is what data is sent between Power BI and ArcGIS? And is this data being stored by ArcGIS?
A: Correct, only the data needed to geocode the address (ie, fields placed in the Location field well) are passed to Esri servers. These data are only used to generate the information used to place the locations on the map and they are not stored by Esri servers.
Q: Does ArcGIS offer a service where this data is not collected for internal use or shared with any partners?
A: As mentioned, we do not store this data. We also do not share it with partners. If data being passed to Esri is a concern, you can use the latitude and longitude field wells to map their point data instead of using the Location field well. When using the latitude and longitude field wells, no data is passed to Esri for mapping – but it does require you to have performed the geocoding process some other way.
Q: Does ArcGIS maps geo-coding have a limit on the number of waypoints that can be sent?  If so, what is the limit?  Is there a limit per day?
A: Limits to geocoding are on a per-map basis and can be found in our documentation here.
Q: Is it possible our address list or search history is never shared for marketing purposes to any partner of ArcGIS?
A: Address list and search history information from ArcGIS Maps for Power BI is never shared for any purpose to any partner of Esri.
more
3 4 4,375
106 Subscribers
