ArcGIS For Excel Questions
92
312.7K
65
Needs Clarification | I am liking being able to see my map in ArcGIS for Excel in the side screen. The problem is, I want a map for my use... by dcopple Frequent Contributor 0 1 | 0 | 1 | |
Under Consideration | Storymaps is NOT PPT! Bring it back! My clients would love it. Instead I am having to try hacks like using Power BI i... by JeffBishopjr Emerging Contributor 0 3 | 0 | 3 | |
Under Consideration | Hi, Community.This seems like it would be a fairly common request, but I haven't seen anything about it anywhere (may... by DerekMStrout Frequent Contributor 1 1 | 1 | 1 | |
Closed | Hello, We have a standalone table within SDE that is published to our Enterprise Portal so that users can update data... by Seamus1Mills Emerging Contributor 0 2 | 0 | 2 | |
Closed | This is a small idea, but would be helpful to improve user experience. Currently, the icons for Show Map window and F... by N8-CORR Occasional Contributor 0 1 | 0 | 1 | |
Closed | Using ArcGIS for Excel it would be great to be able to dock the Agol add-in as a horizontal window. Currently only ve... by KarlvanT Emerging Contributor 2 3 | 2 | 3 | |
In Product Plan | Hi,it will be great if we can use the attribute view for a no hosted layer from Portal of an ArcGIS Enterprise.Best, ... by Rémy_Gourrat Frequent Contributor 1 2 | 1 | 2 | |
Needs Clarification | He creado una tabla de Excel con X, Y luego la he publicado al mapa, después la llevado a online, y la he utilizado p... by AndersonRincon Emerging Contributor 0 1 | 0 | 1 | |
Under Consideration | I intend to make ArcGIS for Excel available in my organisation. I think only a small number of users will be authorin... by DavidHorsey Occasional Contributor 3 1 | 3 | 1 | |
Implemented | I have been bugging the ArcGIS for Office group for years to allow me to see the data form a service in excel. I eve... by DougBrowning ![]() 3 41 | 3 | 41 | |
Already Offered | When the geocoded Excel data range changes, it would be useful to be able to see the map update. Data changes can be... by Piminator Emerging Contributor 1 1 | 1 | 1 | |
In Product Plan | Hello, I think it would be a good idea to set visibility range on Excel. I know that you can set visibility range on ... by Matgo Emerging Contributor 0 2 | 0 | 2 | |
Already Offered | Currently when you filter records in your Excel table, those records are also filtered in the map - a nice feature! B... by EricBushee Occasional Contributor 3 3 | 3 | 3 |
Idea Submission Guidelines
