ArcGIS for Excel error logs are intended to serve as an additional resource when troubleshooting error messages while working with the add-in, in the Excel environment. The information in this log will help identify the error cause and provide context on why the error occurred and how to potentially solve it.
It is important to note that these error messages can occur from Microsoft Excel or from the ArcGIS for Excel add-in, therefore some links may redirect to the Microsoft website.
Errors that may occur when working in Excel.
Category: | Function: | Error output: | Error description: | Cause & Solution: |
Error | Function Builder | #CALC | Unliftable Array: Array cannot be lifted over to call a function on individual array members. | It occurs when a user inputs an array/group of cells (e.g., A1:C5) into the input parameter, when Excel was expecting only one cell (e.g., A1) for this parameter. |
Error | Function Builder | #VALUE! | Generic | A value used in the formula is of the wrong data type. |
Info | Function Builder | #BUSY! | Please wait for the formula to be calculated. |
Warning | Function Builder | #NAME? | Invalid name | There is a typo in the function name. Note that this error is supported as a custom function input error, but not as a custom function output error. |
Warning | Function Builder | #REF! | Invalid reference | The function refers to an invalid cell. Note that this error is supported as a custom function input error, but not as a custom function output error. |
Warning | Function Builder | #VALUE! | Invalid value | A value in the formula is of the wrong type.
Warning | Function Builder | #N/A | Not available | A value in the formula is of the wrong type. |
Error | Function Builder | #SPILL | Generic | Excel formula wants to display its output in surrounding cells (spilling output over to other cells), but there is no space, or the other cells are somehow off-limits (e.g., in an Excel table). |
Error related to the use of the application.
Category: | Function: | Error description: | Cause & Solution: |
Warning | Buffer/Drive Time/Infographics | Additional permissions are required to use this feature. | Contact your organization administrator. |
Error | Add Artic Bathymetry basemap | The basemap could not be loaded. Check the basemap service or select a different basemap. | The Vector Tile Basemap has been replaced as they are not supported by the browser.
Error codes are defined here and organized into groups based on category.
