Where the ability to export images gone in version 400?
599
03-16-2022 07:46 PM
blkcar
Been using version 370 for some time to load aerial images into AutoCAD, then crop & save those images for each specific job. Currently testing the new version 400.2 & it appears that feature has been completely removed. Is this correct?
Its really important to have that export ability as working with huge images continually loading & updating in the background absolutely kills AutoCAD.
If this is correct, are there any other work arounds?
Thanks.
Randy_Garcia
Hi! The export feature is still in ArcGIS for AutoCAD. It can be done from the Contents pane.
If you right click on a layer in the TOC you can select the "extract" option. This will create a .png of the maps current view and insert it into your drawing.
You can also use the dynamic mode on/off from the TOC to stop the map from updating dynamically without having to extract.
blkcar
Thanks for that, really appreciate it.
Shame there's no obvious button.
