Re: Geolocation Problems in Arcgis for AutoCAD
676
03-12-2024 10:34 AM
hancer
Hello,
I am having an interesting problem with the ArcGIS plugin in Civil 3D. I have been using it for a while and didn't have any issues with it earlier. However, recently, I had problems with ESRI base maps. I can bring them into the CAD but I can't remove them as they are not shown in the ESRI contents window as it should . Can anyone recommend a solution? Thanks!
DanWade
Hello,
Thanks for using ArcGIS for AutoCAD!
If possible please log an Esri Technical Support case with the Enterprise-Ext team. We would like to get details about the layers being added to the drawing, the versions in use, The basemaps added, etc. Does it happen if you start a new drawing?
Kind regards.
