Focus is taken away from AutoCAD while attribute table open causes freeze
434
08-03-2018 10:24 AM
PiperMcKinnon1
Hi Don,
I have a user experiencing an issue and I wonder if it is a bug? Her system is Windows 7 64 bit with AutoCAD Map 3d 2018. When working in AutoCAD with the plug-in and with the attribute table open, if she moves focus to a different program on the same screen as the attribute table (eg. to check her email), when returning to AutoCAD, the attribute table does not come to the front, and is not showing in or accessible from the Windows taskbar. Because the table locks the AutoCAD map screen, this renders her project inaccessible and the only way to resolve it is to kill the application through the task manager. I am running a similar setup but on Windows 10 and cannot recreate the issue. Do you have any insights that would help us troubleshoot this?
