Error synchronizing edits with server from AutoCAD
10822
20
01-12-2016 10:50 AM
RandallClark2
Moved from ArcGIS for Server
Update:
i  have 4 services that i am bring in to my cad document. one is polygon, one is line and two are point services.
When i add features and go to synchronize with my server i get the following message, twice
MyMapService: Errors encountered in adding features. error processing server request.
when its over it tells me that the only features that updated were to the line and polygons. the points failed to update. Oddly i can delete features tho.
anyways when i go to check the AGS logs i see the following
Message: Method failed.HRESULT = 0x80070057 : The parameter is incorrect. (more)
Tagert: Landscape/L_Site.Mapserver
Code: 100005
Method Name: GraphicFeatureServer.Add
So it seems the error only happens on my services that are point geometry.
Any thoughts?
original post:
So after adding features to my feature service layer in AutoCAD when i go to sync my edits back up to the server i get the following error
Code: 100005
Can any give some in-site as to what this means?
AhmedElsalloul
I encountered the same Issue however upgrading to 10.4 is not an option for us at this time.
Another option is to turn off the visibility of the date fields in the layer control then publish the Feature Access service.
One tested feature class only contained Date fields used for editor tracking. Removing these fields in the layer control prior to publishing, worked perfectly. The fields also correctly updated in the database record.
A Second tested feature class contained 2 user input date fields and the date fields used for editor tracking. All date fields had to be removed for this to function correctly so it's not limited to just the editor tracking date fields.
Enjoy
