Attribute table in Arcgis for AutoCAD 400 plugin doesn't show properly
167
12-28-2020 06:09 AM
MohamedEl-Shamy
I downloaded ArcGIS for AutoCAD 400 a While ago, but I had an issue I can't find anywhere else. whenever I click the attribute table button it displays a huge clear selection button without a trace of the table itself. It's as if its zoomed in on the button. I tried resizing the table window to no use. The best I managed was to display the zoom to selection button when I stretched the window horizontaly. I can't use the plugin like this and had to switch to v 370 again. I can't attach screenshots of what i get because I'll have to uninstall the 370 version. Is there any way to fix this? PS: the problem never happens when i use ArcGIS for AutoCAD 370. I'm using AutoCAD 2018
Reply
KarenHodge
Hi there Mohamed.  I haven't seen this before.  Suspect it could be an install issue.  Would be worth a call to technical support.
Reply
KarenHodge
Do you, by chance, have High Contrast mode enabled?
Reply
