ArcGIS Pro - How to create a .dwg file to use in CAD?
5313
04-25-2016 03:11 PM
AntonioSaavedra
Hi!
I am using ArcGIS Pro 1.2 version. I created an Excel file with one address and used the "Excel to Table" tool to convert. I then locate the point in this case is a Boy Scout Camp and used the Topographic base map. I then used "Export to CAD" tool to export the Feature file (one address) and created the .DWG file but when BSA open it was blank. What do you think I am missing (a step)? This will be of great help to Boy Scouts National to help them with their maps in CAD.
Thank very much!!!
DanPatterson_Retired
AdrianWelsh
MVP Honored Contributor
Hi Antonio,
I am wondering if you need to make that feature point into a feature class first (export to a geodatabase or so), and then export that geodatabase feature class to a CAD file. Maybe try that?
