ArcGIS for AutoCAD, on AutoCAD 2015
8545
13
05-29-2015 03:39 PM
surens
ArcGIS for AutoCAD; AutoCAD 2015. Can anyone say me when is it going to release..??? as none of the arcgis versions are compatable with the 2015 autoCAD version..
Tags (1)
JayantaPoddar
MVP Esteemed Contributor
The latest release of ArcGIS for AutoCAD (release date: September 2014) supports ArcGIS for AutoCAD 2013, 2014, and 2015.
ArcGIS for AutoCAD | Download
Think Location
JayantaPoddar
Think Location
surens
Thanks for the answer but i want to know when will 2015-16 released..??
DonKuehne
The current release ArcGIS for AutoCAD already support AutoCAD 2015.  Early tests show that ArcGIS for AutoCAD 350 also works unmodified on AutoCAD 2016 although the next release due this summer will be certified on 2016.
DiegoGarcia_Diaz1
Hi, I currently downloaded and install Esri for Autocad 2015, the file name says Autocad 2013 anyway. I didn't think that was the problem, but after the installation I open my Autocad 2015 and I don't see any change. Do i have to activate something later?
SeanGalway
Could it be as simple as loading the ArcGIS for AutoCAD plugin DLL
Loading ArcGIS for AutoCAD  (from resources.esri.com)
During an AutoCAD session, you can load ArcGIS for AutoCAD with the NETLOAD command.
Steps:
  1. Start your AutoCAD program of choice. The AutoCAD application starts.
  2. Type NETLOAD at the command prompt.
  3. Browse to the ArcGIS for AutoCAD program folder.For example: C:\Program Files\ArcGIS for AutoCAD
  4. Select the ArcGISForAutoCAD.dll file and click Open.ArcGIS for AutoCAD is unloaded when you exit the AutoCAD application.
or more permanent solution
Loading ArcGIS for AutoCAD at startup
BenCamp
I'm using ArcGIS for AutoCAD with AutoCAD 2016 and no issues whatsoever. This is build 350.
Navaneetha_KrishnanAsokan
Could you please tell me how to export the feature classes (local) which is created. along with attributes.
BenCamp
In ArcCatalog, navigate to the DWG containing the feature class and then export the feature class to a shapefile.
