ArcGIS for AutoCAD Build 400 - Issues using services published through Pro
642
03-17-2020 01:28 PM
CarltonCounty
New Contributor II
Our design team have recently switched to the 400 version of ArcGIS for AutoCAD. The plug-in works well and has great connectivity with AGOL. Due to the 400 version being a BETA and limited information online, I wanted to share my recent troubles with others before attempting yourself.
We have recently started publishing all our services from ArcPro and hosting a map image layer on AGOL for our design team to access from the AutoCAD plug in.
After much testing, it seems that if you publish a service through Pro, you lose all labeling and selection capabilities when you bring the service into AutoCAD through the plug-in. I tried a multitude of options to try and resolve the labeling and selection issue and the only resolution I could come to was to republish the service through ArcMap.
Has anyone else had this issue?
I just wanted to share this with other users, start a conversation and make it know to Esri
Tags (1)
by Anonymous User
Not applicable
Carlton,
Are the services public facing? If so, would you be able to post the service uri?
