Image Numbering
547
03-23-2022 11:57 PM
Status: Open
by Anonymous User
Not applicable
I was wondering if you would be able to add an option to change how files are collected on the SD card.
For example, my organization uses both a P4P and an Inspire2 and images are titled as DJI_0001.jpg, DJI_0002.jpg, etc
The numbering system continues like this until DJI_0999.jpg, but then it starts back from the beginning again in a new folder starting with DJI_0001.jpg making it difficult to organize the photos afterwards as two images from the same flight could be in two different folders and/or both have the number  DJI_0001.jpg.
If this limit could be removed it would make large projects so much easy to manage as all the images would be saved in one place numbered sequentially.
Thanks for your consideration.
1 Comment
NicoBonnafoux
Status changed to: Closed
Hi @Anonymous User,
Image numbering and folder structure on the SD card is handled by the drone, so this Idea should be suggested to the drone manufacturer.
Note that when transfering the images to Site Scan Flight on your iPad, Flight will automatically organize the images in folders for each mission you conducted.
