ArcGIS Flight - Supported Aircraft and Cameras
15616
07-08-2024 01:03 PM
Labels (2)
BrentPierce
6 5 15.6K
IMPORTANT NOTE: This site is now out of date, for the most up to date information on supported Drones and Cameras for the ArcGIS Flight app please go to the Hardware and Compatibility section of the ArcGIS Flight Documentation.
ArcGIS Flight – Matrix of Supported Aircraft, Cameras, and Lenses
(February 2025)
This resource describes the aircraft, cameras, and lenses that are supported for flight planning & mission control by the ArcGIS Flight app. This also includes the latest test firmware version and supplemental camera configuration information.
Important note: Site Scan for ArcGIS, ArcGIS Drone2Map, and ArcGIS Reality for ArcGIS Pro provide processing of any georeferenced drone image. If your drone is not supported by the Flight app, you may still use the manufacturer's application to capture images for processing in the aforementioned ArcGIS Reality products.
The following aircraft are subject to routine testing within ArcGIS Flight, and their performance can be verified.
Vehicle
Firmware
Supported Cameras
Notes
Freefly Astro Max (NDAA/Blue)
1.9.2, 1.7
Sony LR1 - (NDAA/DIU approved)
Controller Connection Information:
https://support.esri.com/en-us/knowledge-base/connecting-freefly-astro-pilot-pro-controller-to-arcgi...
Freefly Astro
1.5.18 , 1.4.6
Sony Alpha7R IV
Supports both the Herelink and Pilot Pro Controller
DJI Matrice 300 RTK
v05.01.01.00, v06.01.01.00, v07.00.01.00, 09.00.0503
DJI Zenmuse P1
DJI Phantom 4 RTK
02.02.0616, 02.02.0611
Fixed Camera
Requires SDK controller. Controller with built-in screen is not supported
DJI Mavic 2 Pro
01.00.0770, 01.00.0797
Fixed Camera
Compatible Drones:
These aircraft are expected to be compatible with ArcGIS Flight based on testing on legacy versions or simulator testing. They are not subject to flight testing with ArcGIS Flight 5.0 and beyond. Users should be cautious about dependence on these platforms for possible future obsolescence and may consider upgrading their technology.
Vehicle
Firmware
Supported Cameras
Notes
DJI Matrice 200 v2
01.00.0590 & 01.00.0710
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse XT 2
DJI Zenmuse X7
  Has not been tested on version 5.0 of the ArcGIS Flight app.
DJI Matrice 210 RTK v2
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse XT 2
DJI Zenmuse X7
Dual Configurations:
- DJI Zenmuse XT 2 + DJI Zenmuse X7
DJI Inspire 2
01.02.0500 & 01.02.0600
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse X7
DJI Phantom 4 Pro v2
01.00.5000 & 01.00.5200
Fixed Camera
Phantom 4 Pro “+” (Plus) version with controller with a built-in screen is not supported.
DJI Phantom 4 Pro
01.05.0300 & 01.05.0600
Fixed Camera
DJI Matrice 210 v2
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse XT 2
DJI Zenmuse X7
DJI Matrice 210
01.02.0301 & 01.02.0450
DJI Zenmuse X4S
DJI Zenmuse X5S
DJI Zenmuse XT Radiometric Temperature Camera (640 X 512, 30 HZ, 13MM)
Dual Configuration:
- DJI Zenmuse X4S + DJI Zenmuse XT Radiometric Temperature Camera (640 X 512, 30 HZ, 13MM)
DJI Mavic Pro
01.04.0400 & 01.04.0500
Fixed Camera
Not recommended for high-accuracy mapping
Compatible Cameras
Camera
Specifications (recommended configurations)
Notes
Sony LR1 Camera
Latest Specs
P4A Camera
Sensor: 1” CMOS
Effective pixels: 20M
Lens Field of View (FOV): 84°
Focal Length: 8.8 mm / 24 mm (35 mm format equivalent)
Aperture: f/2.8-f/11
Shutter: Mechanical
Fixed camera
P4P Camera
Sensor: 1” CMOS
Shutter: Mechanical
Fixed camera
P4Pv2 Camera
Sensor: 1” CMOS
Shutter: Mechanical
Fixed camera
P4RTK Camera
Sensor: 1” CMOS
Shutter: Mechanical
Fixed camera
Mavic Pro Camera
Sensor: 1/2.3” CMOS
Effective pixels: 12.35M (Total pixels:12.71M)
Lens Field of View (FOV): 78.8°
Focal Length: 26 mm (35 mm format equivalent)
Aperture: f/2.2
Shutter: Electronic
Fixed camera
Mavic 2 Pro Camera
Sensor: 1” CMOS
Effective Pixels: 20M
Lens Field of View (FOV): ~77°
Focal Length: 28 mm (35 mm format equivalent)
Shutter: Electronic
Fixed camera
X4S
Sensor: 1” CMOS
Aperture: f/2.0
Shutter: Leaf
X5S
Sensor: 4/3” CMOS
Effective Pixels: 20.8M
Focal Length: 15 mm / 30 mm (35 mm format equivalent)
Aperture: f/2.0-f/22
Shutter: Electronic
The lens listed is the recommended lens. Other lenses may function but will require manual focal length input in Advanced Flight Planning settings to correctly calculate overlap and sidelap.
DJI Zenmuse XT Radiometric Temperature Camera (640 X 512), 30 HZ, 13MM)
XT Version: Radiometric
Lens Field of View (FOV): 45°
Lens: 13 mm Camera Lens
Max Thermal Frame Rate: 30 HZ
Resolution: 640x512
Shutter: Mechanical
DJI Zenmuse XT 2
Sensor: 1/1.7" CMOS
Thermal Imager: Uncooled VOx Microbolometer
Lens Field of View (FOV): 45° x 37°
Effective Pixels: 12M
Max Thermal Frame Rate: 30HZ
Resolution: 640x512
Shutter: Mechanical
DJI Zenmuse X7
Effective Pixels: 24M
Sensor Size (Still): 23.5×15.7 mm
Sensor Size (Max video recording area): 23.5×12.5 mm
Supported Lens: DJI DL 24 mm F2.8 LS ASPH (with lens hood and balancing ring/filter) / 36 mm (35 mm format equivalent)
Shutter: Mechanical
DJI Zenmuse P1
Effective Pixels: 45M
Sensor Size (Still): 35.9×24 mm
Sensor Size (Max video recording area): 34×19 mm
Lens Field of View (FOV): 63.5°
Supported Lens: DJI DL 35mm F2.8 LS ASPH (with lens hood and balancing ring/filter)
Shutter: Mechanical
Sony Alpha7R IV
Effective Pixels: 61M
Sensor Size (Still): 35.7×23.8 mm
Sensor Size (Max video recording area): 35.7×23.8 mm
Lens Field of View (FOV): 84.1°
Supported Lens: Sigma 24mm f3.5 mapping lens
Shutter: Mechanical
Supported Mobile Devices:
ArcGIS Flight has been tested on the two latest versions of iPad OS . With respect to iPad hardware supported by the app, ArcGIS Flight has been tested on A1 chipset generation and the newer M chipset generation iPads.
ArcGIS Flight is not tested on MacOS or Apple Vision.
5 Comments
JoeBryant1
Any plans to support the Anzu Raptor? I understand that those are essentially DJI licensed designs, produced by a US-based company outside of China that use more secure software (Aloft). They state on their website that they have an SDK available. Maybe a good option for ESRI users with a limited budget that are trying to avoid the potential pitfalls of DJI?
BrentPierce
@JoeBryant1 thanks for sharing. We don't have any immediate plans to support that drone manufacturer in the app but we can certainly consider it for a future enhancement. I will take this request to the team and perhaps we could do a little exploratory research. I definitely encourage you to submit a new Idea on our ideas site  . This really helps us understand the scope of the feature, get clarity on it's implications and it's overall applicability/popularity with existing users.
DanielMelendrez
@BrentPierce Any plans to support the new LR1 payload and the latest firmware (1.6.14) for the Freefly Astro?
Daisyeater
New Explorer
@BrentPierce
Good afternoon Brent, I would like to bring to you/ESRI's attention that under the current DOD guidelines provided to all governmental agencies, DJI is not approved for use anymore.  As of now, we are essentially forced to divest from DJI equipment, therefore ArcGIS flight is effectively useless to most if not all governmental entities in the US (aside from those with a budget to buy the Freefly Astro).
As per 8/13/24: https://www.diu.mil/blue-uas-cleared-list
BrentPierce
@Daisyeater ,
Thanks for your feedback here. The ArcGIS Flight app does support Freefly System's Astro drone and are working to certify their Astro Max offering which can be configured to support the Blue UAS standard if your organization requires Blue UAS certification for it's operations. We are also constantly looking to support the other vehicle platforms our customers might be interested in using for their drone mapping operations.
Contributors
