What causes a Form and the '+" button to disappear?
18366
33
01-25-2021 07:41 PM
MikeSlattery
I am not sure exactly why, but the Form I built is gone in the Field Maps configure pane for the layer, and so is the "plus" button in the Field Maps app.   This has happened before, but I am at a loss to pinpoint the before/after scenario.
I did update the popup in the beta map viewer, and I did add a field to the layer - but there is no indication of why the whole Form is gone as if I hadn't built one.
Once I added the new field to the feature item definitions for the layer, I could add/edit features in the web beta, but there is stlll no Plus button on the app.
To my knowledge no one used the layer in the non-beta map viewer.
fklotz
Hi, it looks like your layer might not be set as editable.  It has to be editable for the + button to appear.
Farley
FionaRenton1
I have this same issue in ArcGIS Enterprise 10.9. It is a bit of a paradox
Katherine_Rudzki
Reporting in from 2024, this issue is still persisting. Has there been any progress in fixing this bug? It's incredibly annoying if you have a little change to make in a popup and your entire Field Maps Designer form is wiped.
NickMcNamara
June 2025, still a major issue. Any news, Esri? This is really really bad.
