Use in ArcGIS Field Maps Mobile Uneditable Layer
1195
01-14-2021 03:05 PM
kkoz490
New Contributor III
Hello,
I have a web map that I created for use in Field Maps which I cannot edit the layer. It seems to be the setting in the web map that choose to use in Collector, Field Maps, or both. When the choice is both, I can edit the layer in Field Maps. However, if the setting is only Field Maps I cannot edit the layer. When only the Collector option is set, I can edit the layer in Collector.
I have tried uninstalling and reinstalling Field Maps. The version I am using is 20.2.0 build 271. I have an Android Active Pro tablet with Android version 10.
Is there some setting I am missing for a web map to only be used in Field Maps?
Thank you,
Kevin
ColinLawrence
Hello,
As @LindeCarmack mentioned, both boxes must be checked to allow editing in Field Maps. I realize this isnt exactly clear, but it gives an organization a way to set a Map to read only a la the "Explorer" experience, or editable like Collector.  Currently the app licensing for editing is based on Collector so if Collector is unavailable, you cannot edit. This is certainly subject to change as we eventually move towards deprecation of Collector and Explorer.
Regards,
Colin
Regards,
Colin
Linde_Carmack
As far as I know there is not a setting you are missing, both boxes have to be checked to allow editing. I have seen other questions related to this same issue and have forgotten to check that Collector box myself more than once. I just submitted an idea based on this issue.
kkoz490
New Contributor III
Hello,
Thank you for the response and submitting the idea.
Kevin
kkoz490
New Contributor III
Hello,
I forgot to mention that the services and web maps are in ArcGIS Online.
Kevin
ColinLawrence
Hello,
Regards,
Colin
Regards,
Colin
