Unable to see attributes of created feature
479
09-15-2023 06:39 AM
GregZartman
I have a AGOL hosted points layer setup with several attributes.  I went into the field maps designer and configured the form for field data collection and this works fine.  However, after I collect a point with data, if I go back and select it, I can't see the attributes unless I select "Edit."
Is there some setting somewhere that disables viewing attributes?  I've never run into this before as previous layers I've setup work fine.
Thanks
AdrianWelsh
MVP Honored Contributor
Greg,
What about your popup configuration? Are all the fields visible in there? Maybe check that out and see if something is checked off.
GregZartman
Thanks.  Configuring the popups worked for me
