Unable to complete operation. FIDS must not be negative
364
10-30-2024 04:22 AM
RobertBorchert
Honored Contributor
Portal 10.#.  current Field Maps
I had an issue pop up.  Field Crews need to attach photos to a project issue location.  Field Maps on iPhone is being used.  Survey123 is not used in this application, but was used to create the origin point feature.
There is a point with a related table.  the photos are attached to the related tab.  The application has been active for several years.
Last week this started happening.
The row on the related table is now showing 2 times.  I verified in Pro that there is only one row.
Now the field crews are not able to submit photos
Survey123 is not being used.
I created a new point and related table row and it does not replicate.
I tried creating a new feature service and the problem persists
I opened the application using Collector. it also shows to entries but did allow me to submit the photos.
