Tracker and Field Maps
756
05-12-2021 10:07 AM
LouiseHarris1
New Contributor III
When using Tracker for location tracking in Field Maps can you undertake data capture at the same time, i.e capturing point features and their associated attributes? My understanding is that you can because Tracker works in the background.
ColinLawrence
Hi @LouiseHarris1 ,
When Tracking is toggled ON in Field Maps, you can continue to perform other field workflows as you would typically perform including data capture, updating, searching, etc. The tracks layer can be loaded into any map from the Layers tool as its stored on the device and displayed alongside your other data while editing. I hope this helps!
Regards,
Colin
Regards,
Colin
ColinLawrence
Hi @LouiseHarris1 ,
Regards,
Colin
Regards,
Colin
