Survey 123 integrated to Field Maps using URL dates not correctly passing
419
01-13-2025 12:36 PM
Kristy_Snyder
I have two date fields and when I use the following link. That date passes at Wednesday, December 31, 1969 instead of the correct date selected. Is there a a particular reason why the date field isn't transferring over and does anyone have a solution?
<a href="arcgis-survey123://?itemID=3269522716034134bba71c30e799ebc1&amp;field:VOUCHER_DATE={VOUCHER_DATE}&amp"><span style="color:#bf3a2b;font-size:18px;">
Tags (3)
DougBrowning
MVP Esteemed Contributor
The only reliable way I have got it to work is in the map set it to use 24 hour time.
I still use Classic Map Viewer and set it like this
Not sure where in new map viewer but try that.
DougBrowning
Kristy_Snyder
That worked, thank you!
