Sign in error via ArcGIS Online - untrusted certificate
10314
9
09-26-2021 10:18 PM
elpinguino
Hi Field Maps Community,
One of our field workers is having issues signing in to Field Maps via his tablet.
He is going through the ArcGIS Online button (not the Enterprise button because we don't have Enterprise.)
I've attached screenshots.
Other things to consider.
I can't physically troubleshoot this myself because the tablet is not with me. I can only direct him.
He hasn't had this issue with the five other tablets we've installed Field Maps on.
I didn't come across this issue when I  was testing Field Maps in the tablets.
HeatherMcCracken
Hi there,
As of the September release, ArcGIS online is using a certificate issues by Amazon CA. The error message you are seeing "The server you are trying to connect to (https://www.arcgis.com) is using an untrusted certificate" seems to indicate that the device does not have the Amazon Root CA as trusted on the device.
To remedy this, you will need to install/trust the Amazong Root CA 1 on the device with the issue.
This link has pretty good steps for how to do this: link
See attached screenshot.
The image on the Left, shows how you can inspect AGOL (or any websites) certificate by clicking on the lock. You can see that it was signed by Amazon (and specifically Amazon Root CA 1)
The image on the Right shows my device's trusted Certificates. Devices should have Amazon Root CA 1 trusted.
Hopefully this helps!
HEather
IhabHassan
Hi @elpinguino
I think you can use something like TeamViewer to be able to manage the device remotely.
Regarding the FieldMaps, are you sure the latest version of the software is installed? looks like invalid cached temp files issue, you might need to use new Profile on this device to make sure you are using latest
Regards
Ihab
elpinguino
That's good advice! Thanks Ihab. I will ask them to check Google Playstore and make sure the latest version is being used.
DeonLengton
Can you log onto AGOL using a browser on the device?
HeatherMcCracken
Hi there,
HEather
elpinguino
Thank you @HeatherMcCracken ! This is just what I needed. Have checked on my own device and sent over to the field workers. Catching up with them tomorrow and will ask how it went. I will keep this post handy. It's a good one.
elpinguino
It turned out the date/time had jumped to May 2022, which screwed over the certs. Not sure what's going on there, but your pointers/articles led them to check the security and find the issue.
WadeBurns
Hi Heather,
We are currently have the same issue as elpinguino and tried applying the solution you outlined; however, that did not help for our instance. Also, the CA1 was already selected (as well as all available certificates on the unit [TDC6000]. We tried unselecting it and reselecting, but that did not give us any different results. Any thoughts or suggestions now?? Maybe there is something else we need to be doing since this is a few years after the issue outlined above. Thanks in advance for any assistance or guidance you might have.
KellyArmstrong
I am getting the same issue, but with Enterprise/Portal, when opening Field Maps or Collector on my Android device.....
ZacharyHart
Honored Contributor
Go see my response to your thread. You are not alone!
