Search is not limited by map extent
356
12-01-2022 11:02 AM
DustinSellinger
New Contributor III
I am using the water distribution system solution and getting ready to train field staff on the Water Distribution Asset Collector fieldmap.  It's a well made map and field map with good options configured for search.  Lots of asset ID's etc.   The extent has been set to our boundaries.
Problem is when searching for a numerical string (part of an asset ID) I get only places back, and the closest is 4,800 miles away.   Well outside the area I'm looking to search.
Why isn't this being limited by the extent?  Besides turning off address search and adding in my own address layer I'm not sure how to work around this.
AprilChipman
Occasional Contributor III
Has anyone had any luck limiting the search distance in Field Maps to be relevant to your organization?
