Search co-ordinates in BNG projection
1795
10-26-2021 12:48 AM
AbhijeetKulkarni
Hi All,
Can anyone please suggest if FieldMaps supports co-ordinates search in BNG projection if my data and basemap is in BNG projection?
Thank You,
Abhijeet
ChrisDunn1
Hi Abhijeet,
BNG searching is supported if your data are using that projection. Have you tried searching and it is not working?
Chris
AbhijeetKulkarni
Hi Chris,
yes, I tried searching. I have shared 2 screenshots from Field Maps webapp. will share FieldMaps mobile app screenshot in some time.
Thank You.
ChrisDunn1
Try including the directional notation (N, E, etc) after the coordinate values, that may solve the issue.
AbhijeetKulkarni
Hi Chris,
It works with format of Easting/Northing in mobile app so good for now. Strange that same format doesn't work in FieldMaps webapp but anyway.
Thank You.
