Saving Customized Layer Visibility
633
03-11-2021 06:41 AM
Linde_Carmack
Is there any way to save layer visibility settings that differ from a web map's default visibility?
I thought this was possible by turning layers on/off in the 'Add Offline Area' window before starting a download. But when I open the downloaded area it reverts back to the layer visibility in the web map, instead of the visibility I set before starting the download.
Is there another way to achieve this?
DougMorgenthaler
@Linde_Carmack the default visibility for layers is defined in the web map and is the location where any changes should be made.  Within the on-demand offline workflow, they layers tool can be used to temporality turn on reference layers that can help find the right area/extent to download.  It also displays any layer loading errors or layers that need credentials entered.
DougMorgenthaler
Linde_Carmack
Bummer, but thanks for clarifying.
