Return Not Detected for Address field insted of Null values for arcade expression
977
09-15-2022 07:52 AM
anonymous55
Hello
I have this code which is from Esri blog and I am trying to return exact address values from parcel data (MapPLUTO) but I don't want to retune Null values instead I want return Not Detected for Address field for cases which code can find address
// If feature doesn't have geometry return null
if (IsEmpty(Geometry($feature))) { return "Not Detected"}
// Get the parcels layer
var parcels = FeatureSetByName($map,"MapPLUTO")
// Buffer the current location and intersect with parcels
var bufferedLocation = Buffer($feature,50, 'feet')
var candidateParcels = Intersects(parcels, bufferedLocation)
// Calculate the distance between the parcel and the current location
// Store the feature and distance as a dictionary and push it into an array
var featuresWithDistances = []
for (var f in candidateParcels) {
    Push(featuresWithDistances,
            'distance': Distance($feature, f, 'feet'),
            'feature': f
// Sort the candidate parcels by distance using a custom function
function sortByDistance(a, b) {
    return a['distance'] - b['distance']
var sorted = Sort(featuresWithDistances, sortByDistance)
// Get the closest feature
var closestFeatureWithDistance = First(sorted)
// If there was no feature, return null
if (IsEmpty(closestFeatureWithDistance)) { return "Not Detected"}
// Return the address
return `${closestFeatureWithDistance['feature']['Address']}`
DavidSolari
MVP Regular Contributor
It looks like the only exit point that can return a null value is the final return for the address itself. You can coerce a null address to your string like so:
var address = closestFeatureWithDistance['feature']['Address']
return Iif(IsEmpty(address), "Not Detected", address)
I think the issue is you're checking if the entire "closestFeatureWithDistance" object is null on line 33 rather than just the Address attribute.
anonymous55
Thanks @DavidSolari
this is working great another question;
some of my features already have address but when I am using this expression is updating address field which I don't want to happen? do you know how can we limit these edits?
JohannesLindner
You can check if candidateParcels is an empty Featureset (no parcels intersected).
Two ways to do that (both after line 9 )
// intuitive, but slow for large datasets (should be OK here)
if(Count(candidateParcels) == 0) {
// not as intuitive, but much faster
if(First(candidateParcels) == null) {
Have a great day!
Johannes
