Popup definition created in new map viewer not used
1030
07-08-2021 03:45 PM
MichaelDavis3
Have created a map in our AGOL tenant using a registered feature service from ArcGIS Server 10.6.1.  Popup definitions created in the new non-beta map viewer don't seem to be used by Field Maps.  Popup definitions created with the "classic map viewer" do seem to work.  Why?
by Anonymous User
Not applicable
This is a current limitation in Field Maps. The new popup elements that are used in Map Viewer are not supported at this time. There is a blog post that highlights some of the limitations when using Map Viewer with Field Maps.
ahargreaves_FW
Hmmm....cross posting to this question. I can confirm that the reason is a lack of capability between popups in the new map viewer and Fieldmaps. I had to use the "classic" map viewer to config my popups. This then displays correctly in Fieldmaps.
https://community.esri.com/t5/arcgis-field-maps-questions/issue-with-popup-in-arcgis-field-maps/m-p/...
HeatherMcCracken
Please check out the latest release of Field Maps (Nov 2022) - where we have added support for popups configured with the (new) Map Viewer.
See the "What's New in Field Maps" blog for all the details.
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/whats-new-in-arcgis-field-maps-n...
