Polyline streaming in Field Maps not working
204
03-17-2025 06:50 AM
KevinBurkman1
Good morning all.
This weekend I attempted to use Field Maps, paired with my phone and Bad Elf receiver, to collect data at an OS preserve that I’m working on:
  • Points- worked as expected.
  • Polygons- worked as expected.
  • Polylines- Has a major issue:
    • I was attempting to collect trails
      • ESRI’s online instructions state that you turn on “Streaming”, walk and collect your trail, then “Stop Streaming” and “Submit”.
        • When I did this, I got an error message stating that I needed two or more points to collect a point.
      • I then selected a point, turned on streaming, walked the trail, selected another point, then ended streaming.
        • The result was a straight line with a point at either end, not a trail with the expected numerous vertices.
The streaming option was definitely turned on in  Field Maps, when I created the datasets.
Any feedback would be greatly appreciated.
Thank you,
Kevin Burkman
KatHerrera
You might check - in your profile Collection Settings in Field Maps check your Streaming setting - that allows you to set how often to collect a new point while streaming.
KevinBurkman1
Stream setting was selected-it's not the issue.
