Points in Field Maps not seen in AGOL
494
10-31-2021 09:14 PM
JenLangevin
New Contributor III
I have captured points in Field maps, sync'd my edits successfully but I cannot see my point in AGOL. The map has editing enabled, offline enabled, etc. I can still see my points in the Field Maps app but I cannot see them when I view my map on AGOL. I checked and the map symbology is not the issue. I'm not too sure where to begin troubleshooting this issue. Ideas?
by Anonymous User
Not applicable
Are you using feature templates with your points?
JenLangevin
New Contributor III
Hello Paul,
I believe I was, I went into Map Viewer Classic, edit, manage, and deleted the templates listed. I changed the symbology to a single symbol. Saved my map, and re synced from Field Maps. I still do not see my points.
by Anonymous User
Not applicable
How did you originally publish your point data? Is it a hosted feature service on AGOL or a feature service on ArcGIS Enterprise?
JenLangevin
New Contributor III
I published it from ArcPro. It is a hosted feature layer on AGOL.
