perte de carte sur esri!
631
12-18-2023 08:10 PM
SamirELHADI
bonjour,
j'utilise l'application fieldMaps avec une carte et donnée réseau depuis un an, mais malheureusement depuis quelques jours cette dernière ne fonctionne plus, en allant dans le compte PC esri je vois que j'ai encore toutes mes données mais que cela ne fonctionne plus, pourriez-vous m'aider a comprendre cela? merci à vous.
samir
RonaldHaug
MVP
Samir has a problem, translated from French...
"I have been using the FieldMaps application with a map and network data for a year, but unfortunately for a few days it has no longer worked, by going to the Esri PC account I see that I still have all my data but it is not working more, could you help me understand this? thank you."
Anyone want to take a stab at this?
HollyTorpey_LSA
Hi Samir,
Can you share a screenshot of what you see when you try to open your map in Field Maps? Are you still able to open the map in the ArcGIS Online Map Viewer? Providing some additional detail might help someone diagnose the issue.
- Holly
