Number field formatting not honored in Field Maps "Edit" mode
1705
03-25-2021 11:33 AM
BrittanyBurson
I have a number field formatted as 0 decimal places at both the layer "Visualization" level, as well as the pop-up within the map.
What I am seeing is that the setting is honored when viewing the record, but not when editing the record. When editing, you see the commas. Is this a minor bug... or an additional setting I am missing somewhere? I do not see it in the "Content" section of the Field Maps web editor.
Thank you! Loving Field Maps so far.
Tags (3)
by Anonymous User
Not applicable
Hi Brittany,
This is by design. When you configure the number and date formatting in Map Viewer or on the visualization tab, you are configuring the popup. If you've configured a form in Field Maps web, the form is used for editing. We decided not to include formatting options because the form is designed for data entry so there seemed to be little need to support custom formats. If I remember correctly, it defaults to the devices locale for formatting numbers and dates. The form and popup are now two distinct things defined for a layer.
It'd be good to understand how this impacts your workflows.
BrittanyBurson
Thank you Aaron for the reply and the explanation. I guess it does not impact the workflow, but has been noticed and commented on by each user we've had test it as feeling messy/inconsistent. I suppose if someone were copy/pasting from the field in the future it could impact the workflow. I will hide the field for now. Thank you
RyanBohan
Please consider adding formatting in the future:  8675309 is not the same as 867-5309.  Of course this would be a text field.  A lot of the time numbers can be coded values and the separators make them easier to read
