I configured the Search Functionality in Web Map using "Find Location" and added Query layers. And When I search in ArcGIS Field Maps I am getting results as "No Title" Records. The layer Configured with Display Field and Configured proper title for Pop up using "Configure Pop up " in Web Map. Please find Attachment for more Info
Hi vijaybadugu,
Sorry you are having this issue. I think this issue would be best resolved if I could see the map, would you be able to share you map with the user arcgisfieldmaps?
Thank you,
Alix
I agree I am seeing this same error. I configure inside of the Settings in the Web Map to search my layer. However after you type in your search in Field Maps app, it gives a result entitled "No Title" no matter what you type. Why isn't it showing the actual attribute that is being searched?
I was having the same issue. I checked everything and finally found that I needed to update the Title in the AGOL map (not Field Maps) under the Tables, not Layers. In the left pane I selected Tables, Popups, and updated the Title in that location.
Hi alix , please republish the service and re-configure the pop up with title . It should be working
I am not alix but republishing does nothing to solve this. Merely keeps showing the same problem.
The layer's pop-up title can be configured in ArcGIS Online map viewer using "Configure pop-ups".
If not configured, the default is going to be "No Title".
