New layer in MMPK is not searchable in side loaded field maps
480
04-23-2024 02:26 PM
kaww02
I have an MMPK created in 3.1. We don't use AGOL but simply side load them to our Field Maps. My new layer's pop-up works fine but when typing in the search bar and hitting enter I get everything but that result.  The field I want to search is a text field with numbers with a dash and a letter in them (example 12345-S01). I assume the combination of data type is the issue, though I have other numbers and text I can search. Is there something I am to do in Pro to make this layer searchable before creating the MMPK? I have not had to do anything in the past, but I know things change often with ESRI.
Thank you!
Tags (1)
kaww02
And.. I think I found my answer. I don't know how I missed this solution:  Solved: how to configure the layer to be fetched in the Fi... - Esri Community
