Must sign into ArcGIS Online to download offline areas from ArcGIS Enterprise
4972
14
01-19-2023 01:59 PM
Jade_Freeman
We've been trying to figure out why users must log into ArcGIS Online when downloading offline areas from a map hosted on ArcGIS Enterprise.  The user is occasionally prompted to sign into ArcGIS Online after defining an offline area in the app and then starting the download.  We are having to create accounts for user in both are on-prem ArcGIS Enterprise portal as well as ArcGIS Online portal.
JoshSkidmore
Sometimes it takes a new set of eyes.  I finally did get a working product.  Thank you for the ideas - it finally works offline.
Royce_Simpson
Thanks Joe.  Turns out, after doing those steps many times with no success, the user that I was trying to use in step 5, I had newly created and thus I hadn't logged into that account to change the temp password, so it kept failing.  As soon as I changed the password, all the steps worked.
Thanks again.
x (x)
ResourceAnalyst
Anybody know how to avoid the AGOL sign in with an imagery basemap i.e. ESRI World Imagery? Unlike the vector basemap there is no prompt to store credentials with the item in Portal 11.1
RachelS
Hi @ResourceAnalyst
Did you ever get a solution to this, I'm having the same problem.
RachelS
