Migrating from Workforce to Field Maps: Auto-Populate Address Field?
826
11-08-2025 04:01 AM
Pili
I have a client who is migrating from Workforce to Field Maps. They noticed that when creating a new point, there’s no way to automatically populate the Address field, although it is displayed correctly in the Field Maps app. This functionality used to exist in Workforce.
I would personally recommend using Arcade to handle this, but I wanted to ask: for those more familiar with Workforce, do you know a way to achieve this during the migration?
Thanks so much for your help!
VenkataKondepati
Honored Contributor
Field Maps doesn’t auto-fill the address like Workforce did. The value you see is display-only. To store it, use an Arcade expression or attribute rule that runs a reverse geocode on the point:
var p = Geometry($feature);
var a = ReverseGeocode(p);
return a.Address;
That will automatically populate your Address field on save. If Arcade isn’t available, use a Python script or post-process workflow to fill addresses later.
Regards,
Venkat
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
RoshanPalikhe1
Hi, did you find any solution for it?
