Long Display Names in Field Maps get Cut Off
774
07-19-2023 02:39 PM
GISJess
Hi I am using an Android phone, and noticed that if a display name is long, it doesn't wrap, but instead is cut off. Is there anyway to prevent this?
See example below
Thanks!
KerriRasmussen
Hello,
Thank you for sharing this issue. It is a limitation of the software that long field names will get cut off. A potential work around would be to make the field name shorter and use the description to add any additional information/ask the full question, since the description has no limit.
Thank  you,
Kerri
