Is there a way to digitize the point only where the user is located?
1031
11
09-03-2025 12:38 PM
JoseSanchez
Good afternoon,
Is there a way to configure Field Maps to digitize points only at the user's current location?
RhettZufelt
MVP Notable Contributor
Looking into this more, still no word on the Center map and add point, BUT, for the Manual location options (Allow, Warn, Block) to work, you need to have the GPS metadata fields in your feature service.  Then the Warn/Block options will work.
However, with the Block setting and snapping off, (and the metadata fields) the ONLY point that can be added is at the GPS coordinates.
BUG-000159708
R_
RhettZufelt
Finally heard back on the other issue.
"BUG-000179551 is currently being evaluated by ArcGIS product teams.
Description: ArcGIS Field Maps does not automatically add a new point when the 'Collecting new features' setting in ArcGIS Field Maps Designer is set to 'Center the map and add a point at your location'.
During this review process, the product teams evaluate the customer impact, level of effort, and potential implementation timelines. There is no guarantee that this change will be implemented; however, the product team actively monitors it, and you will be notified of future updates."
