Is it possible to remove "Add" button from related records that are added using survey123?
1357
04-07-2022 06:36 AM
BrandonBoisvert
I have configured a survey123 form to populate a hosted feature layers related table that is available as a hyperlink in the parent features pop-up. It works great, however, it would be nice if when field workers open the related records, the option to add a record directly through field maps was disabled. I didn't configure the tables form in field maps so the 'Add' button opens to a blank form, but to avoid confusion, it would be best if the 'Add' button was not visible. Hopefully this is possible!
DougBrowning
MVP Esteemed Contributor
Have you tried in the web map - turn off all editing for that layer.  You probably want them to only edit in the form anyway.
DougBrowning
BrandonBoisvert
Thanks, Doug!
