How to apply contingent values in Field Maps
14646
17
11-07-2021 10:24 PM
Marokapara
Hi Field Maps community,
I am working with farmers to map out vegetation types on their land.
The idea is that they the vegetation polygons in and fill out the attributes themselves using the Edit widget in Experience Builder.
My plan is to apply hierarchical conditionalities so the attribute filling out process is simple for them. I assume I'd be doing this through Field Maps, which would feed into the Edit widget.
The answers to choose from in subsequent questions would be based off of how they answer previous questions.
The screenshot below shows what I am trying to do.
My arcade level is basic. I understand how to use conditional visibility in Field Maps, so how to make a follow-up question appear if the first question is true or false. I don't know how to control the drop-down answers in that follow-up question based off of the answer to the first question. Does anyone have a link to a good tutorial or can provide some instruction here?
As a side note, I've set up the contingent values in Arcpro and published that layer into AGOL, but they didn't appear when I tried editing it in Map Viewer, when I tested it out in a Field Maps form on mobile, so assume too it won't work in Experience Builder.
I know as a safe and back up option, I can load each of the fields in individually, however would like to avoid that because it will take a long time, and I think there must be a better way to do it!
I appreciate your help. Thanks for taking the time to review my post.
by Anonymous User
Not applicable
I am also very interested as to when field maps will support this. Can anyone clarify this please?
If I understood from the above posts correctly that contingent values work within an enterprise environment when publishing feature services referenced from an enterprise geodatabase does anyone know what versions of ArcGIS enterprise support this please?
KathyMulcahy1
I want to know the same thing any updates for 2023? I have my tree collection layer, I can do it in ArcGIS pro for contingent value. However, I can not get to the web application or field maps.
Thank you very much.
LauraTomás
Are contingent values support in Field Maps already?
HollyTorpey_LSA
Yes, but they have to be created and managed in Pro: What’s new in ArcGIS Field Maps (May 2022)
- Holly
SarahSaint-Ruth
ArcGIS Field Maps supports contingent attribute values in the form. Once you have published your services from ArcGIS Pro you need to add these fields to the form using Field Maps Designer. Help on how to set this up is available in the doc. You just need to scroll a little to Add contingent field groups to the form.
If Field Maps Designer is new we have a 5 minute video here.
tiztrain
@SarahSaint-Ruth these contingent values can't be published from ArcGIS Pro though right? So in my case I have these templated datasets in a Pro project. The organisation uses these templates in Pro to create standardised forms for Field Maps and Survey123. In your approach, the form would have to be configured every time for every project?
SarahSaint-Ruth
Hi @tiztrain
You're absolutely right — while contingent values are published from ArcGIS Pro, the form itself isn't. That part needs to be configured in Map Viewer or Field Maps Designer after publishing.
To help with repeatable workflows, we’ve recently added a template option in Field Maps Designer. With this, you can:
  • Publish your service from Pro (including contingent values),
  • Configure the map, form, symbology, labeling, and pop-ups,
  • Then save it as a template to the Field Maps Template Gallery.
This means others in your organization can deploy the template directly from Field Maps Designer — and it will recreate the service, form, and map exactly as you set it up. It’s a great way to standardize across projects without needing to reconfigure each time.
See our whats new blog for more info: https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/whats-new-in-arcgis-field-maps-j...
tiztrain
@SarahSaint-Ruth This is a great step forward and could potentially save my organisation a lot of time! Planning to test it out more for implementation asap 😀
Is applying the contingency rules from Pro needed then? I am guessing as long as all those values are part of the domain, that is all you need?
Initially I see that by creating a new web map from a template, the process creates a copy of each hosted service, which is great. As a suggestion for improvement, would be great to be able to have a parameter in which the user can enter a value that would go in-front of the name of the service. Say if the service is called 'Survey Observations' and I entered 'Big Project' as my parameter then the name of the service would be 'Big Project Survey Observations'. Would make it easy to distinguish between the repeated datasets without manually updating and would avoid having the service's name in the backend be something like 'Survey_Observations_8g9a245huhwewe872fd45hwejwhe4rwu4fh'.
