High Accuracy GPS , leica gg04 plus, Field Maps on Android. Altitude is incorrect
1638
16
05-17-2023 01:30 PM
LaurenceLanglois1
I have 'Zeno connect' running on the Android Tablet. With This Result
This is the result From the point I took in Field Maps.
The Altitude is not in meters, it is about a quarter of the live results on the screen.
Any suggestions?
This is the settings from the "Zeno Connect' screen.
I could not get Z values to show up.
Thanks in advance Larry
LaurenceLanglois1
Thanks for the replies. I am going to make a new more specific post:
I just purchased a new GPS unit ‘Leica gg04 plus’
I am using an android tablet.
The 'Leica Connect app’ displays the correct elevation 72.23 meters Orthometric Height.
 But in 'Field Maps' it stores an altitude of 44.09 (Height above ellipsoid (HAE)).
Does anyone have this Leica gg04 unit, and recording the elevation correctly without post processing?
BillFox
MVP Frequent Contributor
LaurenceLanglois1
I was a block north in the bottom corner of the park. The point came up accurately in field maps.
BillFox
BillFox
if so, can you try your rig out on one of the points near Lake Massapoag?
such as MY0482 in Sharon
BillFox
BillFox
BillFox
BillFox
BillFox
