Hidden Popup Data
549
10-28-2024 02:28 PM
CarsonMorton
I'm trying to reduce the amount of data that needs to be downloaded by the field crews, while not deleting data that is useful to those in the office.
If a field maps only shows certain fields in the popup, is the remaining data still loaded in the background? It seems like it would be a waste to load it when that particular map doesn't allow them to view it.
if not, is there another way to prevent certain fields from loading?
DougBrowning
A view may work for this.  https://doc.arcgis.com/en/arcgis-online/manage-data/create-hosted-views.htm
Not 100% if Field Maps allows this but worth a look.
ZachBodenner
MVP Regular Contributor
To make sure I'm understand what you're asking, you just want to restrict what is visible to Field Workers when they're adding/editing data without removing the actual data fields from the dataset?
Happy mapping,
- Zach
DougBrowning
