Form placement can it be docked on right side of screen in app?
650
04-26-2021 03:21 PM
kmsmikrud
Are there options to change the default form placement on the map within Field Maps? Currently when a user clicks to 'Add' a point on the map, the data collection form goes to the left or bottom of the screen depending on how the user rotates the iPad in our case. Is it possible to change the form to be on the right from versus left-side? A user says this would make their use of the app much more efficient since they are right-handed and using a stylus for data entry.
I haven't found any options or ways to change this.
Thanks in advance,
Kathy
DougMorgenthaler
@kmsmikrud I'd recommend suggesting this as a new idea to allow others who might have the same interest to view and contribute their thoughts.
DougMorgenthaler
kmsmikrud
Thanks @DougMorgenthaler ,
Based on your response, it sounds like it isn't currently possible to dock the menu on the right. I will add it as a new idea. Thank-you,
Kathy
