form in photo attachment arcgis fieldmaps
569
05-31-2024 05:54 AM
TimeonSchot
i am working on switching over a survey123 form to an new set of layers that work in arcgis fieldmaps. the field people are now testing a version. however one of the first things they asked if i could set up the picture like it was in survey123 where they can add a drawing wtih the form function after taking the picture. its a function they are using regulary.
there are of course workarounds by first at the drawing to the picturen and than add it as an attachment. however i figured i was not the only one wiht this question. so i would like to know if someone knows how to set up the photo option so it act similarly as survey123.
regards
ChristopherCounsell
MVP Frequent Contributor
No, this is not possible in ArcGIS Field Maps. Vote for this ArcGIS Idea below:
https://community.esri.com/t5/arcgis-field-maps-ideas/field-maps-comment-or-edit-a-photo/idi-p/13281...
Survey123 has more powerful form capabilities than ArcGIS Field Maps.
