Field Maps search only returns maximum 12 results
1517
03-08-2022 02:20 AM
DavidPike
MVP Notable Contributor
Hi all,
Field Maps app users working on downloaded MMPKs onto tablets then taking offline.
A postcode/ZIP code search is only returning 12 results.  I can't recall any configuration in the ArcGIS Pro project which generated the MMPK to specify the number of results.
We have a request to increase the number of returned results above 12 - Is this a default limit of the Field Maps app or is there a configuration option somewhere I'm missing?
Thanks in advance
ColinLawrence
Hi @DavidPike, 12 is the limit for search within Field Maps (came over from Collector and Explorer). There are no immediate plans to change this. It is based on the area in view when the search is initiated.
Regards,
Colin
DanPatterson
MVP Esteemed Contributor
related question with explanation
Search results in Fields Maps limited to 12 result... - Esri Community
maybe an Idea
... sort of retired...
ColinLawrence
Regards,
Colin
DavidPike
Thanks for the confirmation Colin.
