Field Maps labels not showing since updating to 22.3.0
1753
6
06-29-2022 06:43 AM
PatrickKK
Hi Community.
We are using Fild Maps for our projects.
Since updating from 21.3.x to 22.3.0 the labels in some maps are no more visible.
In Arcgis online, Collector or devices with Field Maps prior 22.3.0 they are visible.
We don´t use offline maps.
To me i seems the update messed it up.
Any sugestions?
Best regards
Patrick
mikibok
Same here. Tested with v 21.3.0 and works perfectly, I see all the labels!
Very frustrating.
dajaho
in our project we encounter this problem as well and since we actually need labels for fieldwork, manually searching for labels through editing each feature costs a lot of time and money! @esri: Please fix this issue as soon as possible.
PatrickKK
The problem is still present in version 22.3.1 of Fild Maps 😕
Any suggestions?
PatrickKK
This workaround by Dong_Kun__VDOT_  seems to have fixed it for us 🙂
dajaho
Thanks, see also my reply there: Very confusing management of Field Maps, but it works now.
JasonHrubizna1
Additionally, I found that if you have labels turned on in ArcGIS Pro, and publish the service layer from Pro, the labels will show up in field maps.  Any labelling settings you set in the webmap will be honoured in the webmap, so you don't need to worry about them being perfect before publishing the service layer.
