Field Maps is creating lowercase GlobalId but AGOL does uppercase
4425
12
12-16-2021 08:01 AM
DougBrowning
MVP Esteemed Contributor
There are a few of us that have been posting inconsistencies with case on globalid.
See here https://community.esri.com/t5/arcgis-survey123-questions/globalid-in-lowercase-from-collector-to-sur...
and https://community.esri.com/t5/arcgis-pro-questions/globalid-inconsistent-display/m-p/291405
I think I may have traced it down to Field Maps.
If I add a feature in a web map in the browser I get uppercase GlobalID.  If I use the exact same map and add in Field Maps it does lower case.
AGOL Add
Field Maps add
Then ArcPro changes the lower to upper for display
So the exact same record shows lower in AGOL and upper in Pro.
The big issue here is my relationship class will NOT match lower and upper so all my relationships are breaking.
At this point I am not even sure the standard?  More info in the posts.
Please help I am going nuts.
DougBrowning
Seeing 123 doing lower case also
And when I look at this form in Pro I again get both depending on the attribute table or the popup
No idea which one is "correct" still.
thanks
DougBrowning
Esri now agreed to update this to a bug   BUG-000146406
thanks
HarshalGharat
I tried to look up this bug but didn't get any information around it. Do you know if this has been resolved?
DougBrowning
No I have not heard anything.  Status is In Review it says.  I tried to escalate it already.
suntoygeo
I'm running into this when working with offline copies of feature services in ArcGIS Pro. - merging a few versions of Survey123 data into the latest version of the survey. I haven't figured out which applications apply which case, but I end up with a mix of upper and lowercase IDs, and broken related tables.
RobertBorchert
Honored Contributor
I believe the issue lies with your avatar.  If you change it to a Vikings Logo the sky will be blue for you once again.
On  a less serious note.  I just looked at the results of all locations collected in the field in the last 3 months for one of my apps and they are all uppercase.
DougBrowning
Where did you look at them?  If you look at them in Pro it will convert it for display.  Look at them in a AGOL map or at the actual data service and you will see lower.
RobertBorchert
Honored Contributor
It could be a conflict between database formats.
Is your data stored in the Cloud or on a server somewhere.
DougBrowning
It is a hosted service.  Esri support confirmed the issue as did others at Esri so I am pretty sure it is not something unique to me.  The hard part is it may look different depending on where you look.  But it is for sure consistent.
