Field Maps form calculated expressions and "require" no longer present
336
05-26-2025 08:20 AM
RubyHammond
Hello. I have build several forms in Field Maps Designer, and have used them for about 1.5 weeks now. For each layer that has a form, I have one field with a calculated expression to automatically generate a number for each new feature created in the later (simply adding 1 for each new feature). I also have set most fields in the layers to being required. I have gone in and tested the forms repeatedly as we are getting ready for our first field season of using Field Maps, and this morning I got onto the Field Maps Designer web app to create a new offline map and noticed that the form is no longer automatically generating id#s, and it is also not requiring any fields be filled in when I add a new feature. Does anybody know what could have caused my forms to stop working in these ways? I thought I could reset the calculated expression but I can't find a way to even access that in the forms on Field Maps Designer anymore. So, it seems I'll have to re-make the forms completely if I want an id number automatically generated.
Thank you!
RhettZufelt
MVP Notable Contributor
Not sure without knowing more about it.  Is it possible you saved the Form info into the map and are opening the feature service in a different map?  Or, vice versa?
As far as the automatically generated number, you didn't say 'what' you were adding 1 to, but if you are getting the max value of a field, then adding one to it, you need to be careful with offline data as if you don't download ALL the data in the offline area, it might 'miss' some of the existing numbers and end up with duplicates.
R_
