Field Maps 24.1.0 Crash on Feature Edit
3542
12
03-05-2024 09:51 AM
Spengler
On Feb 29th we experienced a severe issue across our fleet of Android devices running the new 24.1.0 update. Upon editing a line layer on Field Maps, the app would crash to the android home screen. The line layer is hosted on ArcGIS Online. This crash occurs on all Android devices tested (Samsung Galaxy A34, Motorolla Moto G (5) Plus, Motorolla moto g power (2021), Motorolla moto g(7) power, Motorolla moto g(8) power) but iOS devices are not effected.
In the Log, the only [DEBUG (error)] is this
Tue Mar 05 07:13:48 HST 2024 : [DEBUG (error)] - Uncaught exception!
java.lang.RuntimeException: Failed to call observer method
at androidx.lifecycle.f$a.a(Unknown Source:74)
at androidx.lifecycle.ReflectiveGenericLifecycleObserver.c(Unknown Source:12)
at androidx.
We've temporarily fixed this by rolling back Field Maps to an earlier APK but we would like to raise this issue so it can be fixed and we can return to running the release version of Field Maps.
Any advice would be appreciated.
Best,
Alex
Tags (4)
lizmsnow
Hi Colin,
It appears to only be when editing a specific field (text). I messed with allowed attributes and geometry edits and it was still crashing. Maybe it doesn't like that the default value is null until the user changes it? I've attached screenshots of what I'm getting in the logs.
ColinLawrence
@lizmsnow The null default could be the problem based on the error in the first screenshot; I assume the timestamp on that error lines up with when you are crashing? The second screenshot is unrelated.
Regards,
Colin
ZachEdwards_WDSGIS
Is this still occurring. I am working with a customer of ours that is continually seeing crashes in Field Maps. They are running a Trimble TDC650 (Android 10) and are not using offline maps. It seems to crash anywhere between 5 and 10 times in an ~8hr session. This is when updating existing point layers (attributes and geometry). We have tried both online and offline maps with the same result so we know it's not a syncing issue. It almost always happens when tapping submit too. We are on the latest ESRI Field Maps and Trimble Mobile Manager. Any chance Arcade could cause it to fail this many times per day but not every time a feature is updated? The Arcade simply calculates orthometric height in USFT and a date field using the Now() function to get the collection date to populate automatically. Thoughts?
